Bow Compartment Fiberglass
Postby jwv630 on Sat Oct 02, 2021 1:01 pm
Hi Guys
Rushin' to get stuff done before winter sets in again. 2 questions for ya below. Thanks.
1. I'm getting ready to fiberglass the forward deck in the bow compartment. Thinking 2 layers of fiberglass there. Do you think this is 'overkill'? Note: I've already fiberglassed the bottom
side of the deck before I installed it.
2. If laying down 2 layers of fiberglass, would you:
*Put down the first layer with 3 coats of epoxy; let cure; then the 2nd layer with 3 more coats of epoxy??
*Or put down both layers of fiberglass, one on top of the other dry, then fill with 3 or more coats of epoxy??
Thanks again and good luck,
'Miss Jen II'
Re: Bow Compartment Fiberglass
Postby [email protected] on Sat Oct 02, 2021 9:23 pm
The only justification i see for adding extra layers of glass to the forward deck is to prevent a dropped anchor from making a dent.
Of course, you could also drop a heavy object on any other part of the boat, so you had better put two layers of glass everywhere. :-)
On my boat I'll be installing the pre-cut sea-dek material that CLC sells, and that should give the forward deck all the protection it needs.
I also glassed the underside of the forward deck, but only as far forward as the first bulkhead.
If I wanted to put two layers of glass somewhere, I would probably put down the first layer with one coat of epoxy squeegeed over it, and immediately add the second layer the same way
(and once they both cure, add two more coats of epoxy).
Postby jwv630 on Tue Oct 05, 2021 9:11 am
Hi Doug
Thank you. I'm gonna take your fiberglass advice; makes sense. Getting on it today.
I checked out the Seadek. It's neat but seems to be more for traction and padding rather than strength; might add it at the
end of the build.
Thanks again
Postby [email protected] on Tue Oct 05, 2021 9:29 am
I put the pre-cut SeaDek from CLC in the Skerry I built a few years ago, and I'm very happy with it. I'm sure it has saved me from slipping and hurting myself at some point.
And it has showed no hint of staining, deterioration, or coming loose.
Users browsing this forum: No registered users and 270 guests
