Cabin Storage
Cabin Storage
Postby Brent65 on Tue Jun 14, 2022 11:24 am
Fellow Pocketship Builders,
I thought I would share a mod I just fabricated on my PS to increase cabin storage for small items, like your radio, water bottle, snacks or a torn tee-shirt. See link below if interested:
https://idahopocketship.wordpress.com/2 ... k-welding/
Brent Butikofer
Never Stop Exploring
Never Stop Learning
Brent65
Re: Cabin Storage
Postby Hooky on Tue Jun 14, 2022 6:46 pm
G’Day Brent,
This is a good idea mate, I did this on my previous trailer sailer a Mach 28 and the space provided was big enough to store the toilet paper, chemicals and a first aid kit, mind you this was a slightly bigger yacht but good use of space, well done. I will consider doing the same when I get to that stage.
Been following your Blog and your build is coming along well.
Cheers Terry
Re: Cabin Storage
Postby Dmitriy on Mon Jun 20, 2022 8:26 am
Good modification!
Re: Cabin Storage
Postby jwv630 on Wed Jun 22, 2022 6:54 pm
Hey Brent and Gents
I like that mod a lot! Timely also as that's exactly what I'm working on now.
Hey, any concern about the loss of floatation?? Prob not - but 'Murphy's Law'
has kicked me in the nose more than once when cruising (understated!)
Good luck; best wishes
'Miss Jenn II'
Re: Cabin Storage
Postby Brent65 on Tue Jun 28, 2022 12:05 pm
Jimmy V,
Thanks for the comment and question. My 2 cents...I'll have much bigger issues to deal with if water reaches this level inside my cabin that these storage areas. That said, I did seal the compartment at the back bulkhead to keep things from migrating beyond my reach and to seal the middle chamber for flotation.
Brent Butikofer
Never Stop Learning
Brent65
Re: Cabin Storage
Postby slash2 on Mon Aug 22, 2022 6:06 pm
I just cut the holes for my seat back storage. I temporarily mounted the hatches to show what i did.
I thought (as others did) it would be handy to have a little storage area inside the cabin. Again, like others, I used the back section of the port seat back. I closed off the opening in the last seat back frame, and divided the section into two areas, one atop the other. The lower has a 4" opening to the cabin. The upper one is filled with bits of foam right now, but i may cut another hole to access it. Since I'm losing foam flotation in the other area, I wanted to make it reasonably water tight. I wanted a port cover with an attached lid, but could not find anything small enough.I had already designed a sealing port to use for the cabin vent openings for the Dorades and I used the same design here. I printed it out in ABS on a Stratasys 3D printer. It uses a standard O-ring. A small twist of the cover tightens it down.
I also wanted a place accessible from the cockpit for all the little stuff that rolls around: binoculars, sunscreen, flashlight, etc, so I used the starboard rear seat back section for this. Here I found a small rectangular hatch that fit the area nicely: DPI Marine® DPF912PW - Flush Series 12-3/16" L x 9-1/8" W Polar White Inspection Hatch. I got mine from BoatID.
Another storage idea I had but did not implement would be to put a piece of PVC drain pipe along the inside top of the seat back; open to the cabin. One could roll up charts and store them there. Could even add a screw clean out to keep it dry.
Users browsing this forum: No registered users and 19 guests
