Current Builders' Status
Re: Current Builders' Status
Postby dbeck on Wed Mar 20, 2024 4:01 pm
During the past weeks, we did lots of smaller things such as cut-outs at transom and bow. Basically, we are preparing for painting the upper hull. Trailer ordered.
Postby Hooky on Sat Apr 20, 2024 2:45 am
I finally installed the cabin deck top. As I discussed in an earlier post, I decided to glass the underside of the cabin top to provide additional strength, however I was concerned the extra glass might make installation difficult. I am happy to report it didn't and the cabin top bent nicely into place.
I am back into the build now after a small break travelling around New Zealand and the southern parts of Australia.
I started construction on the Bowsprit. I am considering a decorative mod to the Bowsprit, check out the pics on my Blog.
Cheers
Terry from down under.
Postby [email protected] on Sat Apr 20, 2024 2:15 pm
Hooky wrote:I am considering a decorative mod to the Bowsprit, check out the pics on my Blog.
Don't forget: the tip of the bowsprit WILL bang into things. Mine was originally squared off with slightly rounded edges, and after the first season it was dinged up, and I sanded the tip to a rounded shape.
Postby Hooky on Sun Apr 21, 2024 7:59 pm
Thanks for the info Doug, I’ll add a hardwood section to the end of the Bowsprit. Should look nice against the light-colored Hoop Pine.
Cheers Terry from down under
Postby dbeck on Wed Apr 24, 2024 2:46 pm
We just finished painting / varnishing the upper hull. As with the lower hull, we did go for epoxy primer, then sanding with 240 grid. This was followed by two coats of two-part paint with 400 grid sanding in between the coats. The transom has been varnished with three coats only (we are lazy) of one part varnish, again sanding with 400 grid in between the coats. We basically reused the (slightly simplified) color scheme of #PS1.
There are some imperfections, but there seems to be a general rule that with each coat we introduce a painting bug somewhere. We decided to leave it like this.
Users browsing this forum: No registered users and 268 guests
