Re: BRASS PORTS
Tue Jan 12, 2010 1:49 pm
by Keith
How did you mount the bronze ABI deadlights? Did you just use bronze bolts with the nuts
tightening right on the plywood, or did you put a brass ring on the inside to finish it off?
Re: BRASS PORTS
Wed Jan 13, 2010 10:06 am
by decurtis
I cut out a mahogany ring to be flush with the flange on the interior and epoxied it in place. I then used brass screws to attach the port to now thicker topsides of the boat. Brass bolts would probably be even more secure and with acorn brass nuts would be a nice little interior detail. Supposedly there was a matching brass ring from ABI but at the time it either wasn't available or I thought it was an unnecessary extra expense.
