Track stop on Pocketship mainsail
Re: Track stop on Pocketship mainsail
Postby sean on Tue Dec 10, 2013 1:01 am
Regarding adjustable sail stops, I agree with everyone else - some type of sail stop is a great thing to have, whether a traditional slider or block of wood as shown by Pete.
I had some fun with them over the summer and designed my own. However, to make just a few, they can still be expensive. Just buying a basic thumbscrew alone (in quality stainless steel) can run you as much as $10-15. Same with the sliders, though once the CNC mill is set up you might as well make a bunch. So now I have a bunch of them, and can only figure on dropping so many overboard. To recoup my costs and give everyone else an easy and affordable option, I am selling them for $9 each.
Check out link for more info:
http://buildingpocketship.wordpress.com ... ack-stops/
-Sean
http://buildingpocketship.wordpress.com/
track slide.JPG (106.29 KiB) Viewed 4984 times
sean
Postby Shudoman on Tue Dec 10, 2013 4:03 pm
Nice Sean,
I was wondering since the body seems to be made out of some sort of nylon/plastic, would it be possible to drill a small hole in it so a lanyard could be attach so I WON'T drop it over the side?
regards,
Postby sean on Tue Dec 10, 2013 9:52 pm
Hey Bill,
Great idea! Yes, the body is made from plastic (same material as that used to make the sail cloth), so it would be very easy to drill a small hole to pass a lanyard through.
-Sean
sean
Postby Shudoman on Wed Dec 11, 2013 10:07 am
Thanks. That's really cool and for only $9 I think I can order a couple of them!
Postby [email protected] on Sat Apr 16, 2022 7:46 pm
I have a 3D printer, so naturally I had to design and print a track stop. Here it is:
https://www.thingiverse.com/thing:5355237
Note that the OpenSCAD source code is included.
I happened to have a 1/4-20 stainless thumbscrew lying around, so I designed the part to use it.
If I had to buy a setscrew, I would probably use a smaller one.
Users browsing this forum: No registered users and 302 guests
