Hard To Reach
Re: Hard To Reach
Postby DanaDCole on Tue Apr 08, 2014 7:25 am
Amazing how well web translator works. Are you sure that lead block, which looks to be at least 50 pounds, plus the weight of the battery won't shift the balance too far forward? You've done a beautiful job on it, but I think epoxy is impervious to battery acid. I could be wrong about that. Why not use gel-type battery instead of lead-acid? More expensive but a lot safer in a boat, I would think.
Re: Hard To Reach
Postby DanaDCole on Tue Apr 08, 2014 7:35 am
Say, what material did you use to make that mold? Looks pretty good. I can think of some places where I would want to make that sort of thing. For example, maybe mold solid blocks of lead that fit in exactly in the spaces below the floorboards. Maybe I need to start a new topic about this idea. What are your thoughts?
Re: Hard To Reach
Postby hood on Tue Apr 08, 2014 10:34 am
I want to use motor 5HP Mercury recharging He weighs about 55 pounds.But it will try to ship on the water.The form of plaster for casting lead I did before the front deck.I had a problem working in a small space to add.
Re: Hard To Reach
Postby MatejProchazka on Wed Apr 09, 2014 6:03 am
Obry den, hood, odkud z CR jste? Ja se take chystam stavet pocketship a rad bych se pobavil o tom odkud mate material, jestli jste stavbu resil s SPS a tak.
Mail na mne je harnod75(zavinac) gmail.com
Matej
MatejProchazka
Re: Hard To Reach
Postby MatejProchazka on Wed Apr 09, 2014 9:11 am
All, sorry for the post in Czech. I am just excited to have someone else building PocketShip in the same country as they will have the same materials and legal troubles.
Have a great day, everyone.
Matej
MatejProchazka
Re: Hard To Reach
Postby truenorth on Wed Apr 09, 2014 9:53 am
PocketShip flotilla on the Danube!
Re: Hard To Reach
Postby hood on Wed Apr 09, 2014 1:51 pm
good joke but we Vltava River :lol:
Re: Hard To Reach
Postby Pastorjim on Wed Apr 09, 2014 2:18 pm
I think that is great! Our forum was able to connect two Pocketship guys from the Czech Republic and I got a geography lesson on the Vltava and the Danube Rivers. Sounds like a good day!
Pastorjim
Re: Hard To Reach
Postby buckeye on Thu Oct 29, 2020 7:35 am
I built mine in a tent. It has a series of steel cross-bars and one going down the center of the tent which I could grab and could support my weight getting in and out of the hull and maneuvering around.
Things would have been a lot tougher without that option for support.
I mention this as a way of saying, you might be able to do something in a garage that would give you some hand-holds overhead to use for support as well.
buckeye
Re: Hard To Reach
Postby SMHolmans on Thu Oct 29, 2020 3:14 pm
I fixed some short uprights to the build cradle and bolted support beams to them, across the boat. They worked great for support when working in the bottom of the hull.
Here is a link to the post https://www.theeynshampocketship.co.uk/ ... beams.html
A really good work step and non slip mats are also essential.
Users browsing this forum: No registered users and 49 guests
