herbt wrote:Thanks.
I have used epoxy/graphite mix on 2 other boats and I have found that it holds up very well (one boat completed in 2001) with no need for bottom paint unless you are going to keep it in the water for extended periods of time. This one was sanded to 220 grit. Problem with the graphite mix is tiny air bubbles that are difficult to defeat but patience and dragging a foam brush or foam roller over it repeatedly gets rid of most of them and sanding takes care of the rest. You will need at least 3 coats of rolled on or foam brushed on mix to cover.
Herb
Users browsing this forum: No registered users and 38 guests
