by mark48 on Sun Aug 18, 2019 7:28 pm
Hi all,
I'm following up on my July 29 post which contained a photograph of a split in my tabernacle (on page 3 of this thread). This entry details my ultimate fix.
First, my thanks to the PF Forum participants who weighed in with advice and thoughts, and particular thanks to John Harris. (I could only dream of an enhanced rig with spinnaker....)
My repair: I removed my tabernacle (thankfully I could do so). The split or crack in the wood tracked down and angled such that the inner end seemed to terminate where the side was glued (and screwed) to the tabernacle back. On the outer face of the tabernacle's side however, the split seemed to extend further down. Identifying the terminus of the crack was very difficult however, even when prying it open a bit.
Ultimately, I drilled 1/8" holes at the tabernacle side's top, down along the crack, and at the junction of the tabernacle side and the tabernacle back. (You can see this hole in the second photo just below the surface of the mast, tucked into interior starboard upper corner of the tabernacle's sleeve. I also drilled a 1/8" hole where I thought the terminus of the crack was on the outboard side of the tabernacle. (Woodworking people tell me that drilling a "stopper" hole to arrest crack propagation works in plastic but not in wood, but there seems a difference of opinion on the 'net so I drilled one there.)
I then pushed in un-thickened epoxy using a syringe and 18ga needle (very tough pushing), a syringe without a needle, a length of small dowel to "plunge" liquid epoxy down the holes, all assisted with a vacuum hose sucking on more distal crack openings. When I seemed unable to get more un-thickened epoxy in, I added thickened epoxy to fill the drilled holes and clamped along the entire crack length overnight.
Then, because I don't have complete faith in my glue job given the length of the crack and the difficulty getting epoxy into its entire length, I contracted with a local custom metal-working shop to fashion a bracket of 1/8" aluminum which surrounds the upper ~12" (or so) of the tabernacle as shown in the accompanying photos. I realize this is significantly more bracket than JH installed on PS#1.
The front of my bracket wraps around the forward faces of the tabernacle's sides; it is also one piece (wrapping entirely around the aft face of the tabernacle) so that once the bracket is slid down over the wooden structure (like a sleeve) and the mast pivot bolt is threaded through, no screws are required to fasten the bracket to the tabernacle. This avoids the issue of putting more screws into the wooden tabernacle, possibly weakening the wood (and providing portals for water entry). I realize this is almost certainly more bracket than necessary, but now I'll worry less. It is also more weight up high and to counter this I will add 10# more lead ballast under the mast.
In the future, I'll be especially careful to keep the mast aligned strictly fore-and-aft when raising and lowering it. But I think my tabernacle is now repaired. All that's left is to re-rig the boat and make sure my shrouds are TIGHT.
All the best to all CLC staff and builders, and particularly PS Forum users,
- Attachments
- Tabernacle.d.jpg (114.81 KiB) Viewed 4503 times
- Tabernacle.b.jpg (84.41 KiB) Viewed 4505 times
- Taberacle.a.jpg (75.65 KiB) Viewed 4469 times
