Boom Tent for PocketShip
Postby John C. Harris on Thu Sep 17, 2015 10:26 am
After many weeks of searching, I finally found the perfect boom tent for PocketShip. I used it on a four-day cruise last spring and it fits as if custom-cut for the boat.
It's called the "Pro Fly Rain Tarp" by Eagles Nest Outfitters. It's meant as a rain fly for hammocks, but the fit is just right. It stretches between the mast and the boom gallows and is slightly wider than the boat, providing excellent cover for both cockpit and companionway. I rigged mine above the boom for headroom (you can stand in the companionway), but in truly lousy weather you might set it beneath the boom to reduce the windage and the ability of rain to reach the companionway.
Here's a link to the tarp, available in five colors: http://www.amazon.com/gp/product/B00K30IPCM
Critically, it's made of nylon. Stiff polytarp is extremely noisy in any kind of wind and doesn't pack down nearly as well. This one is quiet and packs into a tiny bag.
Boom Tent 2 - Thumb.jpg (1.04 MiB) Viewed 6603 times
You'll need poles at the front and back to extend the tent out to the sides. I built a pair from solid timber with a sturdy hinge in the middle for easy stowage. They assume a shallow "V" shape when unfolded. They look like this:
Boom Tent Poles.jpg (95.35 KiB) Viewed 6596 times
However, I wasn't all that happy with that solution, and found that the extendable aluminum poles sold in marine catalogs specifically for boom tents were easier to set up and offered more adjustability. The aluminum boom tent poles look like this, visible in the upper right:
Boom Tent - Thumb.jpg (893.12 KiB) Viewed 6572 times
Bonus anchorage scheme: I made up this simple companionway cover so that I could leave the companionway open on cool, windy nights. It's just a scrap of an old Dacron sail, cut to a 53" x 40" rectangle. A 44-inch stick in a sleeve supports the aft end, with guys running down to the spinnaker blocks. The forward corners are lashed to the chain plates. Takes maybe three minutes to set up.
Companionway Cover - 2 - Thumb.jpg (803.42 KiB) Viewed 6670 times
Companionway Cover - 1 - Thumb.jpg (1.5 MiB) Viewed 6648 times
Companionway Cover - 4 - Thumb.jpg (788.23 KiB) Viewed 6623 times
Companionway Cover - 3 - Thumb.jpg (897.06 KiB) Viewed 6608 times
Eventually I'll get all of this and many other "Cruising in PocketShip" suggestions compiled into a blog post.
Re: Boom Tent for PocketShip
Postby DanaDCole on Thu Sep 17, 2015 11:46 am
Wonderful ideas. Thanks John!
Postby craig on Thu Sep 17, 2015 8:36 pm
Thanks for posting these ideas. It's great to learn what is working for other people so you can adapt them for yourself.
I have only spent one night on my boat, but it was extremely comfortable. I ended up sleeping below but there is plenty of room in the cockpit to stretch out there as well.
Postby riverron on Fri Sep 18, 2015 7:32 am
Thanks for sharing the idea. Curious, does the tarp hang over the sides of the boat, so water falls overboard and not in?
Postby John C. Harris on Fri Sep 18, 2015 8:59 am
riverron wrote:Thanks for sharing the idea. Curious, does the tarp hang over the sides of the boat, so water falls overboard and not in?
Yes, assuming there's no wind. If it's wind + rain the cockpit's gonna get wet. One reason for the boom gallows is to form one end of a more elaborate weather-proof cockpit enclosure; I've never gotten around to it on my boat but several other builders have.
Users browsing this forum: No registered users and 198 guests
