I understand that the plans provided by CLC are 1:1 scale. That being said, I assume it is possible to lay the cut panels directly on the plans after they've been cut to ensure the accuracy of the cuts?
Kevin
Hooky wrote:I used carbon paper for the curved bits and found it worked really well, I cut the carbon paper into 6 inch strips and overlapped each piece, I allowed the paper plans to lay fat for a while prior to tracing over the plans and ensured there was no movement during the tracing process.
Hope this helps
Cheers Terry from down under
Users browsing this forum: No registered users and 318 guests
