How much copper wire?
Postby riverron on Thu Feb 18, 2016 8:30 pm
How much copper wire will I need for the build? I have already purchased 2 25' rolls from CLC.
Thanks!
Re: How much copper wire?
Postby slick95 on Fri Feb 19, 2016 5:03 am
Bought one roll but did not use. The copper wire would not have been strong enough to pull any of the lower hull parts together. I used .041 aircraft safety wire, like this:
http://www.aircraftspruce.com/catalog/a ... ckkey=5661
Jeff
Jeff
Georgetown, Tx
slick95
Postby riverron on Sat Feb 20, 2016 7:45 am
Thanks Jeff for the heads up. I have read some of the challenges on here and some of the blogs about pulling the bow together. I did find a spool of electric fence wire I have that is a little bit thicker gauge, so I should be fine. I just don't want to run out once I get started.
Postby ddemasie on Mon Feb 22, 2016 3:05 pm
For my build I used a 19 gauge stainless steel wire that I purchased at Menard's.
The label says it is rated at 25 lbs, - it was sufficient for 90% off all the stitches I made - in those areas needing a little more force (like pulling together the bow sections) I just went with multiple stitches - spaced very close together.
It comes in 30' rolls - 3.99 per role. I think I used a total of 3 or 4 rolls throughout the build.
Dennis DeMasie,
Aurora, IL
ddemasie
Postby riverron on Mon Feb 22, 2016 8:28 pm
Thanks for the feedback Dennis!
Postby John in CC on Tue Feb 23, 2016 12:46 pm
A little advice on getting the seems together at the bow is to be prepared before the action takes place. Have your blocks and screws ready and don't worry about making a few extra holes. After reading all the horror stories I was ready and it really was not that big of a deal.
Postby ddemasie on Tue Feb 23, 2016 5:28 pm
Here is a quick picture of initial hull bottom bow coming together with the 19 gauge stitching - needed to be about 2 inches apart and slowly, alternatively tightening the stitches - I let it 'rest' for a few hours between each tightening - took about 2 days total to get it completely together, but it worked with just the stitching you see here.
Hull bottom - Bow together with multiple 19 gauge stainless stitches
Hull side - beginning Starboard side stitching 3.jpg (119.31 KiB) Viewed 8960 times
Dennis DeMasie,
Aurora, IL
ddemasie
Postby John in CC on Tue Feb 23, 2016 6:19 pm
Nice job! I found warming up the plywood with a heat gun works pretty well. Have your screws and blocks ready to pull things together when you mate the uppers!
Postby ddemasie on Wed Feb 24, 2016 11:14 am
Here is the picture of how I started the process - Used very long stitches to begin with that I tightened down a little at a time - and let it rest for a couple of hours, then came out and tightened again. I covered the plywood with a warm water soaked towel between tightening sessions. I did break a few stitches during the process by tightening a little too much in one 'session', but the other stitches always held the load while I quickly replaced the one that snapped.
4 Hull - Joining at Bow - 2.jpg (24.66 KiB) Viewed 8967 times
Dennis DeMasie,
Aurora, IL
ddemasie
Postby riverron on Wed Feb 24, 2016 12:45 pm
Thanks for all the good advice!
Users browsing this forum: No registered users and 283 guests
