Companionway hood issues
Posted: Tue Jul 04, 2017 8:07 am
Greetings,
I'm starting to tackle the "bit of carpentry" required to make the companionway hood and slide. A couple questions for all you builders:
1. Page 11 of the plans (step 4) says "Install stops in track." I can't find a reference to that in the manual (or on the forum) but it seems that retaining the capability to remove the companionway slide for maintenance would be an asset. That's especially so if one ever needs to clear the drain holes in the hood. Where have other builders placed the slide stops, and how have you still made the companionway slide removable?
2. If I understand the geometry correctly, in the finished PS with the companionway slide closed, water (rain, spray, etc.) will run off the slide, down its sides, and along the plastic slides to ultimately drain outboard of the companionway sills and off the cabin roof through the drain holes in the companionway hood sides. If that's so, it seems to me that the companionway hood slide grooves should be treated with epoxy like every other bit of wood in the boat - and then sanded somehow to allow the companionway slide to move freely. That seems tough in a 3/8" dado, but widening the dado would allow the slide to bounce up and down. Any thoughts on this?
3. The drain holes in the companionway hood sides could be sized larger than the 1/4" stated in the manual at page 280 (to prevent clogging and ultimate wood swelling restricting companionway slide travel - per JH at the 2017 Mystic WBS). Coming from John, that seems like a good idea, but then these holes will penetrate (or protrude through) the companionway slide grooves in the companionway hood sides. Other than allowing a prompt egress for some of the water as noted in 2 above, any issues with this? These holes could best be drill-fill-drilled before the hood sides are attached to the hood face, and before the grooves are sawn (so epoxy doesn't run down the grooves if the holes intersect with the grooves.
4. Regardless of the kit pattern and plans (I can't believe I wrote that!), the aft face of the companionway slide must be large enough in height to overhang the dropboards to keep water out of the cabin. Have builders sized this aft face with the dropboards in place before cutting it and gluing the companionway slide together?
I appreciate any thoughts on these issues - as well as instructive comments about any misconceptions I may have about the geometry involved here, especially before I put saw to wood.
Thanks to all at CLC, and all posters and bloggers.
Mark Nunlist
Mark Nunlist
