Flippin PocketShip video
Postby riverron on Fri Jul 13, 2018 7:33 pm
I thought I would share the video I took last night of flipping my PocketShip. It was actually pretty easy. Hope you enjoy!
https://youtu.be/7ULJFqZlfkE
Re: Flippin PocketShip video
Postby slick95 on Fri Jul 13, 2018 8:09 pm
Great accomplishment Ron and fun video. Doesn’t it look different now in the work shop? Keep at it you are getting close.
Jeff
Jeff
Georgetown, Tx
slick95
Postby mark48 on Sat Jul 14, 2018 7:50 am
Great video - and congratulations on your progress.
I too had the help of a number of strong fellows on that first roll, but when it came time to turn it upright, my help had disappeared. My hull was also on a rolling platform in my garage. I considered moving it to the driveway and getting a tractor / forklift with a sling to lift it to the lawn where I'd roll it upright by hand-and-tires, and then use the forklift to place it on its trailer. Ultimately though, I rolled it in place using two slings, two "come-alongs," and a carrier beam (two 2 x 10's) across the garage joists. The slings were strong rope threaded through pulleys attached to the "come-alongs" and then through foam pipe insulation tubes to protect the developing finish on the boat.
After lifting the boat up with the "come-alongs,", I removed the mobile platform, placed some heavy cardboard on the cement floor (in case my math was incorrect on the beam-to-beam PS dimension compared to the available vertical clearance) and then gave the hull a gentle push. I was delighted to see the PS hull roll over in the slings like a rotisserie with nary a scratch. I then rolled the trailer underneath and lowered the hull onto its final resting place to continue the build.
Good luck on your shipbuilding and keep posting.
Postby riverron on Sat Jul 14, 2018 12:18 pm
Thanks Jeff. It definitely looks different. To me I it seems larger!
Mark, that sounds like a definite accomplishment rolling it by your self. I originally thought about doing it myself, but was glad my family and friends were able to help! They will do anything for free beer and pizza! :lol:
