Location of spinnaker sheet block
Postby SMHolmans on Fri Jul 10, 2020 3:40 pm
Can anyone tell me how far the spinnaker sheet block is located from the rear cabin wall?
Re: Location of spinnaker sheet block
Postby riverron on Sat Jul 11, 2020 9:43 am
Not sure if mine is right, but I put it at 26” from the cabin wall. I just looked at a bunch of pictures and came up with that. John Harris talked about putting it on a track to be able to adjust. With this in mind, I installed about 20” of blocking. This gives me about 10 inches either way to move it. I did note all these dimensions on a piece of paper and saved for reference later.
Postby SMHolmans on Sat Jul 11, 2020 3:52 pm
Thanks Ron. That helps a lot. I am waiting for the sailing hardware pack to arrive, but I doubt very much that it will include tracking for the blocks. I came to a similar conclusion to you about location. I've got time to decide, but wanted to know where to put the wood blocking in the seatback tops to install the fittings.
Postby Mflyer65 on Sun Jul 12, 2020 12:34 pm
If I had spelled spinnaker correctly I may have saved myself a posting when searching the forum.
Thanks Ron and Steve for your info and the spelling lesson.
Mike
Mflyer65
Users browsing this forum: No registered users and 61 guests
