The side pieces for my companionway hood are a couple of inches too long, as cut out according to the pattern supplied. Is this a normal 'feature' of the kit?
Cheers!
riverron wrote:... The front hood template that comes with the kit measures 28 -3/4" wide. The manual states that the width of the entire hood needs to be 30 -5/8"
So I used the pattern to cut the front of the hood. After dry fitting the slide into the hood, the math just didn't add up and it was too narrow!
Now the hood width should be 30-5/8". If you subtract the 1.5" of the two side hood pieces, you get 29-1/8". So the front template is 3/8" too short.
Users browsing this forum: No registered users and 21 guests
