I started the fiberglassing in the rear transom / bulkhead 8 area and I am having a little difficulty in doing the vertical pieces. I am using a brush to apply as stated in the manual, but in order to get it wetted out properly, I am having to apply too much epoxy. It is dripping down to the fillet area and causing it to float some and move when I apply with brush.
I also see the glass threads coming off where I have cut cleats. This causes a glob of fiber to form, which I have to remove.
The horizontal pieces are fine and I am using a brush roller on them, but I can't build a flat boat!
Any tips on applying Epoxy on vertical fiberglass?
