Wider footwell?
Wider footwell?
Postby Aturbeville on Thu Jun 09, 2016 4:22 pm
Is it possible to make the footwell wider? Would it cause any issues?
Aturbeville
Re: Wider footwell?
Postby craig on Thu Jun 09, 2016 9:42 pm
This has been mentioned by several people. I have never considered it narrow, and I wear a size 10 shoe, which fits just fine. Widening it would be simple if you were cutting your own plywood, but if using the kit you would need to manually cut the bulkheads and cockpit pieces, and somehow splice on an extension to the footwell floor. Seems like a lot of work to me for not much gain. As far as space in the cabin, widening it would eat into your "feet" area but wouldn't be too noticeable if you only added a couple of inches. Too far, and you would make it awkward to lay down in the cabin.
- Craig
Re: Wider footwell?
Postby Lazy Lucy on Mon Nov 21, 2016 10:29 pm
On my Pocketship Perfecto, I widened the foot well by 2" and glad did. Still plenty of room down below. I also stretched the length by 1' and extended the cabin as well. You can see my YouTube video search Pocketship Perfecto to see this boat under construction. It sails like a dream!
Lazy Lucy
Users browsing this forum: Google [Bot] and 137 guests
