John in CC wrote:2. A more radical idea (kind of a thought experiment): After raising the mast, insert a pin near the base of the mast/tabernacle and remove the pivot pin. This would relieve much of the leverage on the tabernacle when sailing while still providing the convenience of a tabernacle. You would never sail with both pins in. Reverse the process to lower the mast. A caveat is that the rake couldn't be changed without drilling a another hole in the base, but even this could be alleviated by simply finding the proper rake before committing to drilling the hole for the base pin.
Problem I see is if the halyard fails while sailing upwind, the mast will not fall harmlessly onto the boom gallows. It could and the manual says, "tear the tabernacle right off the boat in a cloud of splitters"...
Users browsing this forum: No registered users and 330 guests
