Sail slides and track
Re: Sail slides and track
Postby TassiePete on Sun Nov 08, 2020 11:32 pm
Hi Mike,
When the lacing is done like it is shown the picture, the line goes slack everywhere as soon as the halyard is eased as the sail is lowered. Because of that, it doesn't bind. The only issue with this setup is that the lacing might get mauled in the tabernacle hinge, when lowering the mast. This is easily fixed by attaching small blocks of wood to the mast just above the hinge, or, a bit of bungee cord to keep the lacing clear of the hinge.
The gaff doesn't really need to be fixed to the mast. The cheek-block is only a few inches above the gaff, and the luff tension keeps the gaff at the mast. There are two holes in the gaff with a loop (a soft shackle) of 4 mm Dyneema going through them. The throat of the sail is attached to that loop and the block is attached to the top of the loop. The tension of the halyard is acting on the throat of the sail - not on the gaff. The gaff is only kept in place by the loop. I do have a little line around the mast to secure the gaff jaws, but it doesn't do anything. Even with a reef in the sail, the gaff stays at the mast by halyard tension and the lacing.
Speaking of reefing: the lacing will need tightening and securing on a little cleat when putting in a reef, but the lacing is never really tight anyway - it merely stops the sail from going too baggy. The tension on the throat halyard does most of the work ...
Peter
TassiePete
Postby Mflyer65 on Mon Nov 09, 2020 2:14 pm
Thanks Wayne and Peter,
I looked at the gooseneck and it had just the very slightest amount of light coming through the middle portion. I went ahead and corrected it and it seems to be better. But I slightly overcorrected on the last try and it actually is significantly better now. Interesting.
I also examined several of the track slides and found some with bent ends that can dig into the surface of the mast if angled hard enough. I removed the track and indeed there were several areas where the mast surface was gouged a bit. I filed some of their edges down. I will try again after the rains come and go here in NC.
Peter,
I am still interested in your method of attachment. Seems the only real effort to make the change would be to build a gaff jaw and then work through the lacing and a few other things to have it all working. I may tackle this as my winter project. I may end up with 2 versions of a gaff by next spring. Of course I would need to remove the slides on the sail and that would leave me more work if I wanted to return to the track method. But, then again, it's really the journey and not the destination for me.
Thanks all,
Mike
Mflyer65
Users browsing this forum: Majestic-12 [Bot] and 176 guests
