Supporting the Removable Tabernacle
Postby buckeye on Tue Dec 29, 2020 2:50 pm
Surfing Youtube I saw a pocketship builder who had glued strips to the outside of bulkhead 2 and I think on the deck as well.
To give the Tabernacle shear support rather than relying exclusively on the bolts through BH2.
It looks to me like an effective way to support a removable tabernacle
I'd like to have a removeable tabernacle but worry that it would be vulnerable in harsh conditions.
Any downside's to this? Looks like a lightweight adder.
buckeye
Re: Supporting the Removable Tabernacle
Postby TassiePete on Tue Dec 29, 2020 10:02 pm
Hi,
I am not sure whether this is what you found. The tabernacle has a pretty tight fit between the brackets and is itself through bolted with 4 countersunk M8 and large washers. On the inside is a 19mm piece of hardwood. The brackets are made from 19mm hardwood, and they are fixed to the bulkhead (and the deck) with epoxy and a few stainless screws. Note the drain holes in the brackets.
So far, nothing has failed ....
Peter
TassiePete
Postby buckeye on Wed Dec 30, 2020 8:12 pm
That looks great.
It's not the one I saw, that one was more like 1x1 cleats.
I like your design better.
I'll go with that. my tabernacle sides are 4/4 mahogany.
buckeye
Postby mark48 on Sat Jan 02, 2021 10:26 am
Hi Mark,
John Harris has posted detailed instructions on how to build and support a removable tabernacle on the PS Forum. See his post dated 10/17/12 in viewtopic.php?f=3&t=450. There are multiple ways one could do this with lots of other posts on "removable tabernacles." My Puffin's tabernacle was made removable following John's instructions - partly so I could get it into a normal garage. I've had no issues with it - and I'm glad I did make it removable as I had to reinforce the top when I had a split in the tabernacle wood. This required my delivering the tabernacle to a local metal-working shop for a week and I was thankful that I could remove it from the boat. See my posts dated July 29 and August 18, 2019 in viewtopic.php?f=3&t=633&start=20.
Have a great time,
Mark Nunlist
Puffin, 2018
Users browsing this forum: Bflat and 58 guests
