It took me a long time to decide what to do re 'secondary' propulsion. For me the option using oars or a yuloh was a non-starter:
1. The boat has too much windage, and I do not want to get into trouble around other boats or at the dock (let alone trying to get home in a breeze).
2. I am too old for this ...
So, an outboard was the only option, and petrol at that ( there are many reasons why electric is not suitable for my purposes ).
The only real question was, whether to mount the motor onto a bracket, or to cut into the transom.
While it may not be pretty, the setup works extremely well:
1. I can get to the motor without having to lean over the transom ( starting, fueling, going reverse)
2. The weight is not way aft.
3. It is not in the way of anything, the rudder clears the prop (always).
4. The 2.3 gets her moving on fast idle, and a bit of throttle pushes her into the breeze.
5. With a few liters of fuel, I have plenty of range.
6. The prop is well clear of the water when tilted up.
7. Because of the noise, I use it as little as possible !
Cheers.
- IMG_1431.jpeg (153.66 KiB) Viewed 2117 times
- IMG_1238.JPG (82.57 KiB) Viewed 2115 times
