Electric Propulsion
Electric Propulsion
Postby Brent65 on Sat Nov 27, 2021 1:22 pm
PS Owners,
Have any of you used an electric outboard on your Pocketship? Can you share pros and cons? Would you buy again?
Best,
Brent
Brent Butikofer
Never Stop Exploring
Never Stop Learning
Brent65
Re: Electric Propulsion
Postby [email protected] on Sat Nov 27, 2021 6:46 pm
I'm also interested in knowing. Over the winter i need to decide what type of motor to get for my new boat (and how to mount it).
Postby Pascal on Sun Nov 28, 2021 9:00 am
My first outboard motor was a Tohatsu 3.5 ....the ethanol gasoline totally messed it up. This past April I purchase the Torkeedo long shaft. It is so quiet I absolutely love it. It pushes the boat just fine .I only need the motor to get in and out of harbor so it is plenty strong enough. At first I was concern about the range of the battery. But I have yet to use the battery below the 60 % . I would highly recommended. My boat ( Naoned ) is now 10 years old and getting her first refit..
Postby slash2 on Sun Nov 28, 2021 9:18 am
Another data point. A friend has a Macgregor (25?) and uses the Torqueedo 1103 to get in and out of the harbor on the Chesapeake Bay. His boat is a good bit bigger than the Pocketship, but it does well. He does carry a spare battery, but we have not needed it.
I'm thinking of using a 24 volt trolling motor.
Postby [email protected] on Sun Nov 28, 2021 11:43 am
Pascal wrote:This past April I purchase the Torkeedo long shaft. It is so quiet I absolutely love it. It pushes the boat just fine .I only need the motor to get in and out of harbor so it is plenty strong enough. At first I was concern about the range of the battery. But I have yet to use the battery below the 60 % . I would highly recommended. My boat ( Naoned ) is now 10 years old and getting her first refit..
How exactly did you mount it to the boat? Does the throttle handle swing up enough to allow the motor to be tilted out of the water?
Postby Pascal on Mon Nov 29, 2021 6:40 pm
I used the typical motor bracket that I originally installed for 3.5 Tohatsu and did not have any problem... Send me your email address at : [email protected] and I will send you a video of it in action if you want.
Users browsing this forum: No registered users and 98 guests
