Outboard Motor Question
Postby SMHolmans on Sat Feb 19, 2022 7:14 am
Hi all. Me again! I'm looking at outboards and my first question is what length shaft do I need?
Thanks!
SMHolmans
Re: Outboard Motor Question
Postby Bflat on Sun Feb 20, 2022 4:10 pm
15 inch (short shaft). That's what CLC uses on the prototype. It's what I happily use,. Clearing the rudder endplate is a consideration and the 15" easily does that. Some have argued for the longer shaft being better in waves. I'm sure that's true, but I would think it would be hard to keep from dragging a long shaft motor through the water in it's up position, especially when heeled, and be uglier. It's a compromise.
Postby [email protected] on Sun Feb 20, 2022 10:30 pm
Bflat wrote:15 inch (short shaft). That's what CLC uses on the prototype. It's what I happily use.
What sort of motor and mount are you using? I have been researching motors and their dimensions, and it seemed
to me that a long shaft would be necessary to get the motor body high enough to keep it from hitting the transom in the up position.
Postby Bflat on Sun Feb 20, 2022 11:12 pm
2.5 HP Four Stroke, short shaft (15"). Mount from West Marine
Postby JonLee on Mon Feb 21, 2022 3:30 pm
I have the same setup. Works well for me.
Postby SMHolmans on Tue Feb 22, 2022 7:03 am
Thanks for the advice guys! Does anyone have experience of electric outboard motors?
SMHolmans
Users browsing this forum: No registered users and 141 guests
