by slash2 on Mon Aug 22, 2022 6:06 pm
I just cut the holes for my seat back storage. I temporarily mounted the hatches to show what i did.
I thought (as others did) it would be handy to have a little storage area inside the cabin. Again, like others, I used the back section of the port seat back. I closed off the opening in the last seat back frame, and divided the section into two areas, one atop the other. The lower has a 4" opening to the cabin. The upper one is filled with bits of foam right now, but i may cut another hole to access it. Since I'm losing foam flotation in the other area, I wanted to make it reasonably water tight. I wanted a port cover with an attached lid, but could not find anything small enough.I had already designed a sealing port to use for the cabin vent openings for the Dorades and I used the same design here. I printed it out in ABS on a Stratasys 3D printer. It uses a standard O-ring. A small twist of the cover tightens it down.
I also wanted a place accessible from the cockpit for all the little stuff that rolls around: binoculars, sunscreen, flashlight, etc, so I used the starboard rear seat back section for this. Here I found a small rectangular hatch that fit the area nicely: DPI Marine® DPF912PW - Flush Series 12-3/16" L x 9-1/8" W Polar White Inspection Hatch. I got mine from BoatID.
Another storage idea I had but did not implement would be to put a piece of PVC drain pipe along the inside top of the seat back; open to the cabin. One could roll up charts and store them there. Could even add a screw clean out to keep it dry.
- Attachments
- Storage.jpg (254.54 KiB) Viewed 4794 times
