Centerboard Pivot Holes from plans
Postby edrzasa on Tue Aug 23, 2022 9:32 am
I have been working on the centerboard and case . My question is in regards to when the holes are to be drilled . There are 5 holes that need to be drilled out and filled with epoxy . 1 - Centerboard 2 Case sides 2 Keel sides . Do I cut the holes for the keel and case at the same time?
0r separately and then line them up ? Also pre or post fiberglassing? just want to make sure it will all line up .
Ed
edrzasa
Re: Centerboard Pivot Holes from plans
Postby Hooky on Tue Aug 23, 2022 4:51 pm
G’day Ed,
I drilled oversize holes and filled with epoxy prior to assembly, then after assembling I levelled the keel and centerboard under a drill press and drilled the bolt holes. This maintained a perfect 90 deg angle. Then I glass over to provide a completely watertight area.
Check out builders' blogs to get some suggestions.
Hope this helps
Cheers mate
Terry from down under
Postby edrzasa on Wed Aug 24, 2022 8:23 am
Thanks for your advice and for sharing your adventure on your bolg.
Ed
edrzasa
Users browsing this forum: Google [Bot] and 356 guests
