- bow chock side view resized.jpg (85.95 KiB) Viewed 3476 times
I have a modified Easy-loader trailer that I adapted to fit my Pocketship. I like leaving bob-stay attached as I have really worked at making it quick and easy to launch for a day sail. My original solution was to just have the winch and rolled real low and that worked ok. My trailer had a 4 inch wide roller style bow stop.
I purchase a 3 inch wide "V" type stop and cut it in half with a hack saw. attached with two carriage bolts from inside to out and added some carpet. I was then able to raise up the winch so it has a more direst pull on boat. Works great.
I think it is ok to have winch fairly low as long as you have boat well secured with transom tie-downs and a safety chain on the bow eye in case winch strap fails. Also, with the keel on a carpeted trough I find it is next to impossible to move boat forward with the winch so I think risk of moving around is minimal. Tom PS Tortuga
