I though I was careful when setting up the keel. When I epoxied the first side, I had the curve just right with a block at the end keeping everything centered from end to end and confirmed with a laser level. I also checked the centerline when I epoxied the second side, but I sitll ended up with a keel that is flat on one side and curved on the other. Not sure where I went wrong.
Should I attempt to fix this, and if so how?
Thanks!
