Newbie Fiberglass question?
First I will apologize since I will be asking a lot of questions during this build.
In the process of putting on the fiberglass, I have a small ridge that goes across the centerboard trunk. It looks like it is where I folded the fiberglass when I was laying it out. I only folded it over once, but I guess once to many. The glass looked perfectly smooth before wetting it out.
The pictures below are after the 2nd coat, so I still have coat 3 which will add more epoxy and even it out some.
This is the closeup using my IPhone and you can see some of the fiber material. The ridge is probably less than 1/32, but I can still feel it with my finger.
![Image](http://i1113.photobucket.com/albums/k509/riverronw/close%20up%20glass%20bubble_zps8jwdlfvv.jpg)
This is the view, which really does not look that bad.
![Image](http://i1113.photobucket.com/albums/k509/riverronw/2nd%20coard%20centerboard2_zps8gzotloz.jpg)
I still have to sand, which will probably take the top off and resolve. Should I add more epoxy to that area and then re-sand again to make sure ALL wood is covered? Other things I should do?
thanks
Ron
thanks
Ron
