Pictures of the cleat? Its the stringer that runs for and aft midway between the CB Trunk and the hull sides. On further inspection it actually separated the bottom layer of ply from the cockpit deck. I did not take any pictures of the damage and its since been repaired. This is the forward end close to where the rear cabin wall joins the cockpit deck. This area of the deck is not well supported except by the rear cabin wall so I think beefing up that joint will help stiffen that area and also put my mind at ease which is even more important.
Herb
