Jeff's pocketship- It's DONE!! except for the sails 4/4/11
Re: Jeffs pocketship progress
Postby John C. Harris on Mon May 18, 2009 8:52 am
I'd leave the drain plug hole. There WILL be water in there eventually, usually from condensation.
I've had a couple of disasters with expandable foam, including at least one exploded boat, and about a dozen boats where the foam became saturated with moisture over time.
Not much danger of the former if the deck is off. As for the latter, I am told that modern foam formulations are much better about absorbing water. All of the water absorption I've seen came after 10 or 20 years, so who knows. The expanded foam in Jeff's boat sure looks beautiful compared to the motley collection of insulation foam in my boat.
Postby jeff on Wed Jul 08, 2009 4:52 pm
New Pictures from 07-08-09 progress:
http://www.flickr.com/photos/35243545@N ... 619831460/
jeff
Re: Jeffs pocketship progress..New Pics through July
Postby John C. Harris on Fri Jul 10, 2009 3:45 pm
Your boat is looking absolutely brilliant, Jeff. That's exceptionally clean epoxy work. Wow.
Postby jeff on Sat Jul 11, 2009 1:56 pm
Thanks John, This is a great project, plans and manual are first rate. I wish I had more time each week to work on it but I'll take the few hours I get.
jeff
Re: Jeffs pocketship progress..New Pics ~07/15/09
Postby terry on Thu Jul 30, 2009 8:36 am
Very nice woodworking Jeff, you are going to have a beautiful boat. Keep the pics coming. The Walrus
terry
Postby mtsailor on Thu Jul 30, 2009 10:34 am
A thought on foam..been there. I've spent many hours digging stinky, water soaked, foam out of compartments on sailboats. The expanding foam was put in by well-meaning persons thinking that it was a good way to sink-proof their nice boat. However, over time, water from condensation or other sources got between the hull and foam, and into the foam itself, and caused a bad mildew stench and mess. I got rid of the mess, but the mildew smell, once in a boat, never goes away. I always believed in the old saying that "everything is waterproof 'til it gets wet", and I don't assume that the forward compartment of the PocketShip is exempt. John's design, foam pieces that will allow air to move around, is a good solution. And I'll be putting screw-in ports in every compartment that can be removed to allow air circulation and drying out of the area when the boat is not at sea. Jer http://gallery.me.com/jermcmanus
mtsailor
Postby jeff on Thu Jul 30, 2009 12:42 pm
Another thought on foam... I investigated the construction methods of Boston whaler and they use a high density closed cell pour in foam sandwiched in the hull . Their boats have been around for years without many complaints. I used the same foam and I hope it works as well for me as it does for Boston Whaler. we'll see.
jeff
Re: Jeffs pocketship progress..New Pics ~09/14/09
Postby jeff on Mon Sep 14, 2009 6:28 pm
Jeff's pocketship progress.. a few new pics ~09/14/09
jeff
Postby 68guns on Mon Sep 14, 2009 8:57 pm
Jeff:
Your workmanship is second to none! What is the story on picture #1608?
68guns
Postby jeff on Mon Sep 14, 2009 11:35 pm
Thanks for the compliment...photo 1608 is a paper template for cutting each section of glass cloth. It just saves time farther down the road. For me that is. Jeff
jeff
