Hatch cover plans?
Hatch cover plans?
Postby Robblackburn on Fri Apr 14, 2023 10:45 pm
Hello,
I have been lurking here for a while but have finally taken delivery of a lovely Pocketship called Kermadec from Tasmania in Australia. I got her home yesterday and have been having a look at the whole thing today with a mate. Beautifully built by Peter Kreb. Faultless everywhere I look
My question to the group is that the hatch cover around the hatch slide has a few weathering issues and I don't have a set of plans for the boat. I have bought a copy of the building manual but as the boat was built from a kit I don't think Peter got a set of plans.
Is there anyway I can get hold of the plans for the bits and pieces that make up the hatch cover without buying the whole lot?
Rob Blackburn
Robblackburn
Re: Hatch cover plans?
Postby Tom G on Tue Apr 18, 2023 9:21 pm
Hey Rob, I don't know what part you are trying to repair exactly but I have attached a photo of portion of plan page 10 that shows some detail. My Pocketship was built by someone else and I needed to fix quite a few builder errors that made the boat unusable but I did have the plan set that came with the boat.
If that is not it you might try asking CLC for help with a drawing. When needed to fix some errors made by original builder they were a big help. I got a pdf of the tabernacle for example and later a pdf showing where bow eye should be located. They will likely help you Tom
companion slide.jpg (69.78 KiB) Viewed 2251 times
Tom G
Postby Hooky on Fri Apr 21, 2023 4:42 am
Rob,
I sent you a PM on the "User Control Panel."
give me a call.
Cheers mate Terry
Postby Robblackburn on Sat Apr 22, 2023 4:18 pm
Thanks for that. Have got it back to bare wood and it is drying out nicely so reckon I am ok and won't have to rebuild. Will epoxy and glass in a few days. Is drying quickly actually.
Rob
Robblackburn
Users browsing this forum: No registered users and 108 guests
