Pocketship at Florida 120 with a bimini
Postby Jray on Wed May 24, 2023 5:22 pm
I took my 10 month old Pocketship ‘My Seasonal Rose’ down to Pensacola, FL from Greenville SC last week. Florida 120 is a fun regatta (no racing) that goes from Pensacola to near Fort Walton Beach and return, along the Intracoastal Waterway. Had a great time with a lot of nice folk in everything from a Hobie Cat to a 28 ft trimaran (they needed the room with family of seven!) We all camped along deserted beaches each night. There were around 40 boats total. This was my first sail outside a lake and really enjoyed the stronger, more consistent sea breezes. Never held the same tack for 4 hours before. (Although there were also times we had tack upwind for several hours.) Also had to deal with a narrow channel with a 2 knot tidal flow on the bow and less than 2 knot advance from the wind - IE I used the motor for 10 minutes to get out of there. Also towed another boat that ran out of gas.
https://flic.kr/p/2oCAvic
https://flic.kr/p/2oCFKMi
To prepare for 5 days in the Florida sun, I designed and built a bimini so I could sail in the shade. I salvaged an 8x8 awning to build triangular bracing, attached to the boom gallows poles. I laced a cover on the resulting 4x5 ft framework. To allow this, I had to change the main sheet. I took the same cockpit attachment point and went straight up from there, via 2 double blocks, to the boom. I used the 2 double blocks to get more advantage since the boom attachment point was now further forward. I didn’t have a ratchet block anymore but I just looped the extra sheet around a cleat once, back into my hand to provide enough friction. And yes, sometimes I looped around the cleat enough to hold it fast, despite John’s admonition about never cleating a main sheet. (See above about the 4 hour tack in a steady wind)
https://flic.kr/p/2oCFKMy
Jray
Re: Pocketship at Florida 120 with a bimini
Postby slash2 on Sun May 28, 2023 8:49 am
I like the Bimini idea. I think I’ll need something similar to that for summer sailing on the Chesapeake. It would seem that sheeting the boom at its aft end would make a Bimini easier to do, but I suppose the gallows would interfere with that?
Postby Jray on Sun May 28, 2023 1:31 pm
Yep, sheet behind the boom gallows would angle forward and snag across the gallows uprights when boom was to either side - so not cool. Attached in the middle, the sheet now runs diagonally completely forward of your seated piloting position, so its actually out of the way better.
Jray
Users browsing this forum: No registered users and 290 guests
