I've wired up the 2 hull panels and BH7. On the port side, there is just enough room to push the side panel thru, but on the starboard side I"m about 1/16-in too thin! The bulkhead is in line with the cradle.
Has anyone else seen this problem and how did you fix it? I'm thinking of rasping that side down to a point where I can just push the side panel thru.
