I'm worried I'm doing something wrong when mixing the MAS epoxy. I'm using my drill press with a helix mixing paddle. The press is set at it's lowest speed of 750 rpm. When I mix a batch, it turns milky. I've used it that way when sealing the panels and it dries crystal clear and seems to be very hard. The same when doing fiberglass.
I was on the MAS website and came across a note saying you should not mix it till its milky as it is putting air into the mix and will therefore be not usable.
When I mix by hand, it also seems to get somewhat milky, but not to the extent the machine mix gets.
Am I doing something wrong here?
