Bow Eye install 2
Bow Eye install 2
Postby Dmksails on Sun May 11, 2025 12:03 pm
I've drill the holes for the bow eye and it fits pretty well, except it's not flat against the hull. I'm considering to either -
1. Bend the washer to fit
2. Cut into the hull and make a flat base for it to sit in.
I will remove this when I glass thebottom
What do you think?
Dmksails
Re: Bow Eye install 2
Postby [email protected] on Sun May 11, 2025 5:54 pm
Dmksails wrote:I've drill the holes for the bow eye and it fits pretty well, except it's not flat against the hull. I'm considering to either -
What do you think?
When you prepare to glass the bottom, you will round down that joint A LOT.
The issue you are concerned about will mostly go away.
Postby Pasi in Finland on Wed May 14, 2025 4:32 am
when at the same stage, I took some fairly thick epoxy mix and roughly molded a platform around the two holes. I then used a sander to make a flat for the washers and shaped the rest to nicely blend the into the hull lines. I am happy with the results.
I put two bolts wrapped in plastic sheet in the holes to prevent them from being contaminated.
The method worked for me.
Pasi
Pasi in Finland
Users browsing this forum: No registered users and 106 guests
