epoxy finishing
epoxy finishing
Postby arnie on Sun Jan 15, 2012 9:20 pm
would it be okay to lay down a final coat of epoxy and NOT finish with paint or varnish in areas of the boat where sun will not be a factor and/or are not exposed (eg beneath the floorboards/areas where floatation foam will be) ? Just looking to save time and get sailing! cheers
arnie
Re: epoxy finishing
Postby tattoo on Sun Jan 15, 2012 9:51 pm
I've always thought it OK. An advantage is that it is easier to then glue (I.e., epoxy) things to surfaces under the floors. I plan to glue boards restricting the movement of the ballast in case of a knockdown. Pete McCrary
Re: epoxy finishing
Postby JonLee on Mon Jan 16, 2012 5:15 am
I didn't finish the watertight compartment in the bow. From a personal satisfaction point of view, I'd still sand and paint the areas under the cabin sole. In the context of how long the whole boat takes, it won't add that much time. By the time you are on the water, you'll be glad you spent a couple of "extra" days getting the details right.
Users browsing this forum: No registered users and 7 guests
