Bubbles in Fiberglass
Postby jwv630 on Sat May 19, 2012 1:28 pm
Hi Everyone:
I'm fiberglassed the centerboard with the first coat of epoxy last night. When I checked it this afternoon there were some small bubbles around the edges. Is it best to:
*Leave as it and apply 2nd/3rd coats of epoxy?
*Score bubbles with a razor and apply 2nd/3rd coat of epoxy?
*Cut out bubbles with a razor and apply new pieces of fiberglass in their place? (note that the bubbles are quite small; 1" x 1/4")
*Other?
Thanks very much for your suggestions......Good luck
Re: Bubbles in Fiberglass
Postby Shudoman on Mon May 21, 2012 10:23 am
For me it's always been easier to handle bubbles right away. I generally cut them out, apply a patch that covers the entire area and overlaps the remaining fiberglass and then I feather it in with sanding after the filler coats. Adds a little bit of time and effort but it's a good fix.
Regards,
Postby jwv630 on Mon May 21, 2012 10:29 am
Bill:
Thanks. I'll try it.
Regards,
