Gluzilla
Gluzilla
Postby DanaDCole on Wed Mar 05, 2014 11:15 pm
I have a tube of MAS's Gluzilla, which I have not tested as yet because the nozzles (two are included) can only be used once. I don't know what they use for a thickener and they don't say on their website. According to CLC it is about the same consistency as Vaseline and in the picture looks similar to silica-thickened epoxy.
My hope is to use Gluzilla for the "tack welds" and similar jobs during stitch and glue construction of the hull. Has anyone tried this product? I there some reason it is not a good idea to use it as I am planning?
Re: Gluzilla
Postby Shudoman on Thu Mar 06, 2014 2:59 pm
That's a perfect use for that product. In fact it works very well in many situations. The downside it exactly what you expressed. There are only 2 mixing tubes/nozzles and once they clog up from non-use they have to be replaced. Essentially you only have two session to use the entire tube.
