Today I was joining the two lower pieces at the bow. I clamped the plywood to the cradle and continues forward to the bow with the stitching. As I work my way forward the amount of pressure increases dramatically the closer to the bow I got. I rigged up ropes across the hull and turned a stick twisting the rope to pull the sides together...I did this in three spots and it worked pretty well until I got to the last few 5 or six inches. I then remembered the heat gun trick. After applying the heat the bow pulled together with just my fingers. I will be be using this again in a couple of days when I stitch the sides on!
Hope this helps someone down the line like the many posts I have found on the forum. Hopefully this is one of those gov back moments : ) Thanks guys!
