New Blog and Some thoughts on Laminating
Postby alyssa on Mon Sep 12, 2016 12:29 am
We started a new blog about our Pocketship build and we have some thoughts on a different way to do the filleting and laminating. We'd be curious to see if anyone else has dome something similar.
http://pocketshipskidbladnir.blogspot.com/
alyssa
Re: New Blog and Some thoughts on Laminating
Postby riverron on Mon Sep 12, 2016 8:36 am
Welcome and thanks for starting your blog. It is always nice to see how others do things. I have basically been following the manual, since I have no previous boat building experience. For the bow, I didn't have to heat it, but I did drill additional holes to use to help force it together. I also used a tie down strap, but would recommend being very careful with it. The ratchet can put too much pressure and break the wood. I did like your jig for the bow! I am at the point of starting to sand my fillets, so I could not use your method. I do plan to do what you' did to put the extra fiberglass tape on the joints. I will be following your blog for updates!
Users browsing this forum: No registered users and 293 guests
