Lift out section position
Postby Pasi in Finland on Sat Mar 20, 2021 9:47 am
Greeting,
I have progressed in my build to making the floor, and having just completed the first lift out section. I placed it between floors 4 and 6 as the manual calls for, but now see a lot of others have moved it one floor position forward to between 3 to 5. Is there a reason for this that I’ve missed?
Pasi
Pasi in Finland
Re: Lift out section position
Postby [email protected] on Sat Mar 20, 2021 7:00 pm
Actually, couldn't it run from 3 to 6, to give you even more access?
Or possibly even the entire length could be removeable?
I just installed my floorboards last week (with the removeable parts done according to the plans), and before
I could spend much time admiring them, I had to cover them up to prepare for the deck installation.
Postby Pasi in Finland on Sun Mar 21, 2021 1:09 am
True, they propably could. I think it is inevitable that things are going to fall through the gaps into the bilge, so it would be good to have access. However it is too late for me as I’ve cut the boards :) . I will leave the screw heads exposed to allow at least slow access.
Pasi
Pasi in Finland
Users browsing this forum: No registered users and 142 guests
