Anchor Size
Anchor Size
Postby PerraHunter on Thu Jul 08, 2021 4:03 pm
Good Afternoon,
What is the recommended anchor size for the Pocketship? The Danforth type seems to hold well where I am, although I am open to suggestions. Mostly sand or mud bottoms. I can get a 13 lbs Danforth cheap, but it seems way way too big.
Thanks.
PerraHunter
Re: Anchor Size
Postby Arjen on Sun Jul 18, 2021 9:39 am
I did some “research” before I bought mine.
The Danforth anchor is a popular one for a long time already. It is quite large indeed and good in (slushy) mud.
In sand I don’t know its performance.
The more modern anchors are usually more handy and a bit smaller. They also perform a bit better and are more multi purpose.
Look for example for a rocna or a delta anchor. I bought a delta anchor and the recommended size for the Pocketship is around 4 kg (9 pounds). This depends a bit on how and where you are going to use it. In high wind or current situations you’d better take one heavier (around 12 pounds)
Arjen
Arjen
Users browsing this forum: No registered users and 135 guests
