Dragging a Kayak with PS?
Postby truenorth on Wed Jan 30, 2013 4:28 pm
I saw a video of a sailor dragging a small sit-on-top, plastic kayak behind his 17' boat down the Florida Keys. Ignoring the obvious travesty of having a plastic kayak vs. a wooden one, is that something PS can manage without too much of an impact on her performance? The thinking is to have an available mode of transport for fun and/or emergency.
Any other considerations? (outboard issues, sea conditions?)
Re: Dragging a Kayak with PS?
Postby tattoo on Thu Jan 31, 2013 12:05 pm
Tattoo's present tender, Pluto, is a CLC Eastport Nesting Pram. When towed, she probably slows Tattoo down a little, but not a whole lot. When tacking (or other sailing maneuvers), she just tags along without requiring any special attention. For an overnight cruise I like to have her along so I can explore the shore or just row or sail around the harbor. The pram (when nested) can fit into Tattoo's cockpit when trailering. The smaller "half" is easily loaded/unloaded into (or out of) the cockpit, but the heavier (about 50+ lbs) is much more difficult (for me). Usually, at the ramp, I can recruit a helper. With two, it's fairly easy. Tattoo's first dinghy, Copycat, is shown below.
Spars & furled sail in their Sunbrella cover and stepped. The rig may also be laid flat on the thwarts.
I'm now considering a small light-weight kayak as a replacement for Pluto. I'd like a tender that I wouldn't need help loading/unloading for road transport. Before Pluto, I had Copycat, a Nutshell Pram (WoodenBoat Magazine kit manufactured by CLC). It wouldn't "nest" and had to be cartopped. Copycat is FOR SALE ($1,999 oars, sail, beach dolly, etc) and, if I replace Pluto with a kayak, Pluto will be for sale too.
Early morning (May 2008) at Gunston Cove, Potomac River.
Construction complete. Everything inboard (excpt 8" of the mast), ready for towing.
Fall 07.jpg (122.17 KiB) Viewed 15753 times
Postby kayakgirl on Thu Jan 31, 2013 11:49 pm
I'm planning on towing my wooden kayak and having the best of both worlds--Pocketship for crossings and comfortable camping, and my kayak for exploring shorelines. I was thinking it might be tricky getting into the kayak from Pocketship, but perhaps a paddlefloat with the paddle secured under the bungies on the stern deck would stabilize it enough. Or maybe a little boarding ladder designed just for that purpose would be worth it. I'll find out!
kayakgirl
Postby Donm1753 on Fri Feb 01, 2013 2:45 am
They're not pretty, but an inflatable kayak makes a good, stable tender. If you have a battery onboard you can inflate it when you get to your destination rather than towing it (although they tow fairly well too). We chartered a sailboat up in Alaska and they used inflatable kayaks for tenders. Entry and exit wasn't that hard, even with full winter clothing.
Donm1753
Users browsing this forum: No registered users and 342 guests
