Jeff's pocketship- It's DONE!! except for the sails 4/4/11
Re: Jeffs pocketship progress..New Pics ~09/14/09
Postby ahamm on Fri Sep 18, 2009 4:51 pm
Just looked at your pictures - Wow -- beautiful work. Is it a safe assumption that this is not your first project ?
ahamm
Postby jeff on Fri Sep 18, 2009 9:08 pm
No it's not my first project. I've built a Pygmy Kayak and a CLC Annapolis Wherry. The wherry was a ton of fun to build and very much like the Pocketship but much smaller.
jeff
Postby drunkensailor on Wed Oct 21, 2009 10:34 pm
To Jeff,
I looked at all of your pics on flickr and your pocketship looks perfect. I was just wondering how you got the epoxy filets so smooth and even, also what is the green stuff around the flooring (it looks like felt).
Walter
drunkensailor
Postby drunkensailor on Sat Oct 24, 2009 3:53 pm
Jeff,
I have a couple more questions about your pocketship. First, why is there an access hole to the foam filled section of the bow? Also, when using stitch and glue construction, do the stitches remain under the epoxy or are they removed at some point? Last, do the epoxy fillets contain any fiberglass or are they just resin and filler? I hope I'm not asking too many questions, I'm sure your busy but I appreciate any advice you can give.
Walter
drunkensailor
Re: Jeffs pocketship progress..New Pics ~11/11/09
Postby drunkensailor on Fri Nov 13, 2009 8:03 pm
Your boat looks amazing! I can't wait to see it finished.
drunkensailor
Postby jeff on Fri Nov 13, 2009 10:04 pm
Thank you , I can't wait to see it finished as well.
jeff
Postby longboarder on Mon Nov 16, 2009 5:03 pm
Jeff, how did you do the pinstripe inside. Looks great!!! Is this build from a kit or plans?
longboarder
Postby jeff on Tue Nov 17, 2009 12:27 am
Longboarder, the stripe was done by a car pinstripper, this was a simple job for a car guy.
jeff
jeff
Postby longboarder on Tue Nov 17, 2009 10:54 am
jeff wrote:Longboarder, the stripe was done by a car pinstripper, this was a simple job for a car guy.
Great Idea to breakup that line. Can't wait to see more pics.
longboarder
