Dmksails wrote:Hi All -
The manual has the bow eye getting installed at the very end of the build. I'm getting ready to install the side panels and I'm wondering if now might be a good time to do the bow eye while I have clear access to the bow. It's kinda hard to tell, but from the manual it appears that the bow eye is install at the top of the hull panel, or maybe a bit higher into the side panels.
The attachment Bow.jpg is no longer available
One issue is that the exterior of hull is normally glassed after it is flipped, and you definitely don't want to leave a gap in the glass (especially in the reinforcing tape along the stem) where
the eye goes.
Also, I recommend installing a drain plug at the very bottom of bulkhead 1, and trying to fill in any space ahead of the bulkhead and below the level of the plug.
Towards the end of our first season of sailing, I opened that plug and some seawater came out. I realized that my sealing job around the bow eye was not as good as I thought.
I had to remove it and reinstall it with better caulking. I was very glad I had access to the nuts that held the eye in place - since I had successfully installed the eye in the assembled boat, I
know I would be able to remove and re-install it.
BTW, I used "Loctite PL Marine Fast Cure" for caulking the eyebolt and sealing the companionway hood to the cabin roof, and I am happy with it. It is very strong, dries fast, and Lowe's carries it.
Lastly, after my first season I installed a second eye at the bow just for the bobstay. Now I can leave it attached all the time:
- bobstay2.jpg (196.54 KiB) Viewed 25865 times
